P0420
Old Feb 23, 2019 | 12:13 AM
Aviator 77's Avatar
Default P0420
Hopefully someone can help. I have a 2002 silverado . I've never had a p0420 code or issue before and iv had the truck for 4 years. It always passes smog. Except this year I got the code. I installed a new cat and cleared the code drove it around and the service light came on again. I checked the code and it's the p0420 code again. It says catalytic emissions below threshold. I dont know what other problem it can be. Anyone have any clues. Thank u.
Old Feb 23, 2019 | 12:44 AM
did you buy a cheap cat? bought the complete ypipe from reputable name?
the other faults for this code are bad 02 sensors or leaking exhaust.
Irish_alley's Avatar
I'm here for the party
bad O2 sensor it would be behind the cat. could also be from a cat flowing too much air (high flow cat or exhaust leak)
Old Feb 23, 2019 | 12:48 AM
if you had a lazy precat o2 the fault will set. the cat monitor compares from and rear 02 sensor cross counts to determine the fault.
Old Feb 23, 2019 | 1:26 AM
Aviator 77's Avatar
I didn't buy the cat from a dealer. I payed 260 for the cat. I cut the old one off and welded the other one in.
Old Feb 23, 2019 | 1:27 AM
Aviator 77's Avatar
I do have some exhaust leaks but there before the cats
Old Feb 23, 2019 | 7:51 AM
hey tech i love you, but not in a bad way lol. i have experience with older chevy motors (pre 96) but not so much with these new ones. im learning more and more from you, thank you. for some reason i cant keep the concept of an O2 sensor being "lazy" in my mind they either work or they dont.
Old Feb 23, 2019 | 7:52 AM
where is the leak, before or after the first O2?
Old Feb 23, 2019 | 11:47 AM
how the monitor works...comparing cross counts/switching of the o2 sensors...the front should switch at a much faster rate than the rear...when they switch at the same rate...computer thinks the cat isn't working.
fix the exhaust leaks. clear the code. if the fault resets....and the o2 sensors are working properly...its the cat. Cheap cats have low cerium content....the oxygen storing element in the cat. I have seen cheap new weld in cats set the code. putting in a quality part was the fix.
so, I would do this. clear codes after each step. if the code does not reset...no need to proceed with the next step.
-fix leaks
-make sure 02 sensors are good
-replace cat
Old Feb 24, 2019 | 3:58 PM
Aviator 77's Avatar
The exhaust leaks are before the cats.
