PLEASE HELP!!! Check engine codes
Old Jan 16, 2020 | 12:26 PM
Ethan Hooper's Avatar
Angry PLEASE HELP!!! Check engine codes
I have a 2001 Chevy Silverado 5.3l LS and it has a bunch of check engine code most being related to the circuit. If someone could help me figure out why I have all the codes that would be great. The truck runs fine and shows no issues whatsoever. No check engine light either.
here are the codes
P0101 MAF sensor performance
P0102 MAF sensor circuit low frequency
P0103 MAF sensor circuit high frequency
P0106 MAP sensor performance
P0108 MAP sensor circuit high voltage
P0112 IAT sensor circuit low voltage
P0113 IAT sensor circuit high voltage
P0117 ECT sensor circuit low voltage
P0118 ECT sensor circuit high voltage
P0121 throttle position sensor circuit insufficient activity
P0125 ECT insufficient for closed loop fuel control
P0128 coolant thermostat
P0131 HO2s circuit low voltage bank 1 sensor 1
P0132 HO2S circuit high voltage bank 1 sensor 1
P0133 HO2S slow response bank 1 sensor 1
P0134 HO2S circuit insufficient activity bank 1 sensor 1
P0135 HO2S heater performance bank 1 sensor 1
P0137 HO2S circuit low voltage bank 1 sensor 2
P0138 HO2S circuit high voltage bank 1 sensor 2
P0140 HO2S circuit insufficient activity bank 1 sensor 2
P0141 HO2S Heater performance bank 1 sensor 2
P0151 HO2S circuit low voltage bank 2 sensor 1
P0152 HO2S circuit high voltage bank 2 sensor 1
P0152 HO2S slow response bank 2 sensor 1
P0154 HO2S circuit insufficient activity bank 2 sensor 1
P0155 HO2S heated performance bank 2 sensor 1
P0157 HO2S circuit low voltage bank 2 sensor 2
P0158 HO2S circuit high voltage bank 2 sensor 2
P0160 HO2S circuit insufficient activity bank 2 sensor 2
P0161 HO2S Heater performance bank 2 sensor 2
P0171 fuel trim system lean bank 1
P0172 fuel trim system rich bank 1
P0174 fuel trim system lean bank 2
P0175 fuel trim system rich bank 2
P0200 injector control circuit
P0230 fuel pump relay control circuit
P0300 engine misfire detected
P0325 OCM knock sensor circuit
P0327 knock sensor circuit low voltage
P0332 knock sensor 2 circuit low voltage bank 2
Old Jan 16, 2020 | 4:03 PM
since the money light isn't on, then maybe there isn't a problem. Clear the codes then wait and see what happens. Maybe your battery just ran too low.
Old Jan 17, 2020 | 7:18 AM
I have a code scanner and I have cleared the codes and they are still there.
Old Jan 17, 2020 | 3:25 PM
kevinkpk's Avatar
My take is replace the pcm/ecm. All those codes are related to high and low voltage on the end device i.e. MAF sensor, also with the fuel trim issues is probably causing the misfire.
Old Jan 18, 2020 | 12:31 AM
That's an expensive conclusion to jump to.
I would check the cheap options first. Like make sure the power distribution system is in good shape.
OnDaGround
Feb 1, 2019 12:23 AM
in2pro
Feb 12, 2018 5:55 AM
The Chevro
Nov 22, 2016 7:28 PM
rabbit0102030
S10 & Blazer DIY and Useful Threads
Mar 5, 2014 7:36 PM
shnormo
Feb 12, 2007 12:09 AM
