Po175
Old Dec 12, 2023 | 12:19 PM
abunai23500's Avatar
Default Po175
2000 K3500 7.4L
I have a PO175 code.
Looking through the possible causes, I found that the TPS and MAF could also cause the code.
I was wondering, if either the TPS or MAF were bad, wouldn't It trigger both PO175 and PO172?????
Why would only the PO175 come on????
Old Dec 13, 2023 | 10:29 PM
chem_man's Avatar
15 Year Member
Try reading this:
https://www.yourmechanic.com/article...-blake-griffin
in order to learn what all can cause a P0175 DTC before you decide that this part or that part is defective. Remember, a DTC tells you that there is a problem with a circuit or a system. It never tells you that this part or that part is defective. You have to do some testing and that is called diagnosing.
Good Luck!
Skeeda
Jul 25, 2023 10:27 PM
Bryanward1891
Sep 25, 2019 5:19 PM
62catalinagreg
Sep 19, 2013 2:00 PM
Danimal669
Nov 12, 2012 9:34 PM
bobbobgb1
Jun 23, 2012 9:21 PM
