Rough idle only when engine is warm
Old Sep 22, 2022 | 8:32 PM
Lane.Kristynik's Avatar
Default Rough idle only when engine is warm
I own a 2001 Silverado 1500 LS extended cab with the 5.3 v8 drives fine no lights on, but when you sit idle after its been running and the engine is warm the truck will shake and fill like its going to die out. when you give it gas it sound like its bubbling then when you drive it again it clears itself back out.
I have taken it to the mechanic, they could never get it to act up for them. They put 150miles on it trying to get it to do it again but it wouldn’t. I have replaced my vent solenoid, purge canister valve, my fuel pressure sensor, my charcoal canister. All the mechanic told me to do as most of them are inexpensive. When I replaced those I had a check engine light with codes for a random misfire, high fuel pressure, and a I forget the other one but was for the fuel vent system. Now there is no codes. Truck drives fine until I sit at a light to long, or park it that’s when after some time it starts to bog and like it’s starving for fuel. Today the battery voltage dropped from about 16 to 14 while it was having the bad idle and my ac stopped blowing cold. So I shut it off for like 5 minutes and started it and bam was just fine again. I couldn’t wait for it to do it again because I had to go back to work. But that’s why I’ve come here to see if anyone else has had this issue because I’m just at a stand still with it now.
Old Sep 23, 2022 | 2:10 AM
chem_man's Avatar
15 Year Member
You need to do 2 things. One, find out what the fuel pressure is. If you do not have a fuel injection system pressure gauge, you can get a loaner from O'Reilly, Autozone or Advance Auto parts for leaving a deposit. The factory spec for fuel pressure is 55 - 62 psi.
Two, check the operation of the fuel pressure regulator. If fuel runs out when you remove the vacuum line, then the internal diaphragm has ruptured and the fuel pressure regulator needs to be replaced.
Good Luck!
johnselby
Aug 2, 2022 2:19 PM
wbywmu
1988 - 1998 (GMT400)
Dec 26, 2020 6:58 PM
tombstone
Aug 25, 2019 11:11 PM
Ermartinez11
Feb 16, 2013 12:33 AM
mphayes
Jun 30, 2008 6:03 AM
