Service engine light on and off
Old Jan 12, 2018 | 4:51 PM
Jcm59's Avatar
Default Service engine light on and off
We have a 2006 Silverado 1500 extended cab. The service engine light has been coming on and going off for sever years. We first took it to the dealer and they said nothing wrong with it and it was probably a faulty sensor and would have to replace the instrument panel. I could not afford that it seems to come and go off when ever we hit a bump in the road. We live on a dirt road and it is a little rough but it can just be a bump going down the street. We have alway been lucky in the sense that it has been off when it ever we have to get it smoged. But lately it has been staying on for long periods and it is due to get smoged next month if it is on it won’t pass even if there is nothing wrong. Not sure how to fix this.
Old Jan 12, 2018 | 9:44 PM
get the code read and post the code here
Old Jan 13, 2018 | 12:04 AM
Jcm59's Avatar
Default No codes
there are no codes that’s the problem if there was I would no what to fix
Old Jan 13, 2018 | 5:31 PM
hard to say over the internet...my best guess would be a cluster problem. if you could get a cheap one from pnp to swap in. if that fixes it have it sent away for programming.
Old Jan 13, 2018 | 5:56 PM
Jcm59's Avatar
What is a cluster
Old Jan 14, 2018 | 1:19 AM
Instrument cluster or as you called it instrument panel.
instrument panel cluster...the mil light that is coming on...its part of the cluster.
Old Jan 14, 2018 | 8:30 AM
Jcm59's Avatar
Than you I will look into replacing it hopefully not to difficult. It’s due for a smog and the light was off yesterday hopefully it stays off tomorrow so we can get it smoged. Is there a part inside the panel that is responsible for like a loose bulb or bad connection that I can check
Old Jan 14, 2018 | 1:32 PM
its a led soldered to a circuit board. youtube it.
to pass the emissions test...the mil must come on at key on as part of the bulb check function. Its should turn off when started and all of the I/M monitors must run and pass. If any are incomplete...no pass.
