Should I change my transmission fluid now?
Old Mar 20, 2021 | 7:31 PM
  #11
wow just sudden death. I wonder what happened. I don't suppose an autopsy was done.
Old Mar 20, 2021 | 8:46 PM
  #12
hanky's Avatar
I have never opened up a trans after a fluid flush, so I have some reservations as to just how much good they do.
I can tell you there is always some sediment to be found in the pan after removal and if the filter is changed, the pan cleaned you are absolutely sure there should be no crap circulating around that wasn't removed once disturbed by a flush and hopefully not getting into close fitting valves in the valve body.
Old Mar 21, 2021 | 7:33 PM
  #13
SupereBK's Avatar
Sounds the the best approach is drop the pan, clean any sediment out, replace the filter and then top it off. thanks all for the insight.
Old Mar 25, 2021 | 9:08 PM
  #14
oilcanhenry's Avatar
170K is a long time on a filter/ fluid drop, if it's never been done before, That means your break-in fuild is still in there. With all those particles, contaminates and such circulating and worn-out additives. Forget 20000 miles. I'd flush sooner like 10000 miles. Should have a magnet on the pan that will be full of metal. My 15 Malibu has no such pan, filter or magnet so 20-25k will be changing time for her.
VanKo
Dec 3, 2020 10:18 PM
ChevyVanMan
19
Sep 12, 2018 11:19 PM
curtis1512
Jul 1, 2017 2:16 PM
Chevy1212
Sep 3, 2013 8:49 AM
blazerman
Apr 5, 2008 11:08 PM
