Notices
Starting Issues
Old June 25th, 2024, 9:42 PM
frank1's Avatar
Default Starting Issues
Hello, am wondering if anyone else has the following issue; My truck is a 2002 Silverado with 6.0 engine, when first starting, in the morning, it will crank over no problem, but will not fire. When I turn the key off and retry, it starts no problem and for the rest of the day it starts fine. It then repeats all over again the next morning. Any thoughts
Old June 26th, 2024, 7:13 AM
It sounds like the check valve in the fuel pump assembly is bad. Spray some gas or starting fluid into the throttle body and if it starts right away, then it is the check valve.
frank1 (June 26th, 2024)
Redz315
Uplander
February 5th, 2018 6:30 AM
KrKangas
March 21st, 2015 12:29 PM
bob450
November 20th, 2010 5:13 PM
ffarv
April 9th, 2006 1:52 PM
Quick Reply: Starting Issues
