Starting Issues
Old Jun 25, 2024 | 9:42 PM
frank1's Avatar
Default Starting Issues
Hello, am wondering if anyone else has the following issue; My truck is a 2002 Silverado with 6.0 engine, when first starting, in the morning, it will crank over no problem, but will not fire. When I turn the key off and retry, it starts no problem and for the rest of the day it starts fine. It then repeats all over again the next morning. Any thoughts
Old Jun 26, 2024 | 7:13 AM
It sounds like the check valve in the fuel pump assembly is bad. Spray some gas or starting fluid into the throttle body and if it starts right away, then it is the check valve.
Redz315
Uplander
Feb 5, 2018 6:30 AM
KrKangas
Mar 21, 2015 12:29 PM
bob450
Nov 20, 2010 5:13 PM
ffarv
Apr 9, 2006 1:52 PM
