starting problem 2004 z71
Old Feb 15, 2023 | 2:32 PM
chickendenny's Avatar
Default starting problem 2004 z71
my problem is if the truck is cold it starts immediately. If it is hot it will turn 10 or 15 times before it starts. I have replaced injectors, crank sensor, fuel pump, knock sensors, mass airflow , o2 sensor. It all started when i replaced the injectors. It also is showing po- 174. Cannot figure it out. thanks
Old Feb 15, 2023 | 6:26 PM
install a fuel pressure gauge and check for fuel pressure leakdown.
Old Feb 16, 2023 | 4:59 PM
no fuel pressure loss new fuel pump
Old Feb 16, 2023 | 9:55 PM
how long did you monitor presssure after shutdown?
Old Mar 2, 2023 | 12:23 PM
with gauges it did not drop within 24 hrs
Old Mar 2, 2023 | 12:25 PM
24 frs
Old Mar 2, 2023 | 1:37 PM
typically a long crank after a hot soak is from fuel leakdown causing a flooding conditions. but yr not seeing that.
p0174 is fuel trim to lean. is this code from b4 the repairs or is it active now? if actvie now; engine at operating temp; check the fuel trim with your scan tool and idle and held at 2500 rpm. report for both bandk1 and bank 2.
webby00011
Jan 21, 2015 7:47 PM
stairwayto7
Feb 20, 2013 10:45 PM
nogoodhood
Sep 26, 2011 12:26 AM
septicsavior
Dec 11, 2010 1:00 PM
