Starts after it sits for awhile bogs down then dies
I have a 2004 Silverado 1500 v6 Manuel trans all stock no power anything Manuel sears windows locks everything and I’m having a problem I was driving and it turned into a mechanical bull and I had to pull over the truck would start and idle but sound like it was about to die. I got a buddy to tow me home and have been trying to figure out what’s wrong. I rand a code reader and it said my canister vent solinoid was weak so I replaced that and still nothing. My fuel pump turns on so it’s not that but the trucks acting like it isint getting enough gas. Somone said it could be eletrical but I have spark and don’t know how to tell if it’s something else. Could my fuel pump be bad and not working right or is it somthing else? I’m gonna replace my fule filter today after school and work cause mabye its clogged but I don’t think that’s the problem. Thanks
Just because the fuel pump is turning on doesn't mean it is supplying the correct pressure needed to run the engine. Put a tester on it and those 4.3's run around 58-65 psi.
If that is good then you move on to the next thing.
yancmo
May 12th, 2015 9:10 PM
