Notices
Steering problem Help!!!
Old June 22nd, 2024, 12:47 PM
justinB22's Avatar
Default Steering problem Help!!!
I bought a 2006 silverado 4x4 a few weeks ago. Replaced the tie rods, ball joints, upper control arms, pitman and idler arm.
after installing everything, the inmer tie rod is making contsct witt the cv shaft mount. And the center link is hitting the pumpkin where the fill port is. The inly thing i can see is that the passenger side of the center link is higher than the driver. And the moog pitman arm isnt seating all the way up. I am at a total loss.
Old June 22nd, 2024, 8:48 PM
what were the part numbers
Old June 22nd, 2024, 9:48 PM
Rednucleus's Avatar
Did the replacement parts look identical to the old ones?
Old June 23rd, 2024, 7:59 AM
justinB22's Avatar
yes they did.
Old June 23rd, 2024, 8:09 AM
justinB22's Avatar
Inner- Es3488
Outer - es3493T
Idler -k6534
Pitman - k6535
Lower BJ -k6541
UCA- rk80669 and rk80670
Old June 23rd, 2024, 8:46 PM
1/2 , 3/4 or 1 ton? Engine? quadrasteer?
Check your Z trim height against specification.
procedure for checking Z trim height: https://charm.li/Chevy%20Truck/2006/...n%20Procedure/
Old June 24th, 2024, 5:13 AM
justinB22's Avatar
1/2 ton. 5.3l. And no quadrasteer.
would the Z height have any affect on the center link in relation to the differential?
Old June 24th, 2024, 8:10 AM
on a 1/2t with independent suspension, no probably not.
Old June 24th, 2024, 10:59 PM
Pitman - k6535
according to Rockauto, 6535 is an idler arm, not a Pitman arm
You want
6536 (4 groove), or
6654 (3 groove)
these are for a 2007 and up.
Old June 25th, 2024, 9:06 AM
justinB22's Avatar
You want
6536 (4 groove), or
6654 (3 groove)
That was a typo on my part, 6536 is the correct number for the pitman arm I have.
as far as the UCA’s, the website had them part numbers listed incorrectly on the listing. I looked at the UCA’s themselves and the part number stamped on them is CK80942
brunder
June 1st, 2024 6:40 PM
suburbans_are_cool
June 22nd, 2023 2:31 PM
josealopez1
2014 - 2018 (GMT-K2)
March 15th, 2023 12:05 PM
Weller41
1988 - 1998 (GMT400)
December 31st, 2019 12:36 PM
woodie1987
Nova & Chevy II
December 22nd, 2015 10:55 AM
Quick Reply: Steering problem Help!!!
