Throttle body repeated failure???
Old Feb 16, 2024 | 4:27 PM
kevinmelliott1@mail.com's Avatar
Angry Throttle body repeated failure???
Hi new user need help replaced the throttle body 3x now after “reduced engine power” always the same failure code, replaced the throttle body pedal position sensor assy. Lasts about 3 months each time, something has to be causing it. I just don’t know now??
2006
silverado 1500LT
4wd, 350 5.3L
extended cab
tgank you
kevin
Old Feb 16, 2024 | 4:37 PM
That's what happens when you shoot parts at a problem without diagnosing. Post the failure code please.
Do you have any engine modifications, after market addons, etc?
Old Feb 16, 2024 | 6:26 PM
error is always p2135 have it read every time same error, started by replacing throttle body failed, then replaced pedal sensor, failed, replaced throttle body again(put it on another vehicle I had that was fine (used fir parts runs) it immediately failed in there, then replaced wire harness, failed again! Position sensor is on throttle body!
so I have a new throttle boy, new wire harness, new pedal sensor,no mods that I know of, no add ons that I know of just failed again I appreciate the help but I can do without sarcasm because this isn’t my first rodeo, if I have mud diagnosed it let me know where and how!
thanks again
kevin
thanks Kevin
Old Feb 16, 2024 | 10:07 PM
Zero sarcasm. I am dead serious
Would be nice if you provided complete information in your first post.... I'll save everyone else the trouble of looking it up for you here, but the fault he is getting is "throttle/pedal position sensor/switch A/B voltage correlation"
Obviously whatever you did didn't work, otherwise you wouldn't be here
Except, what you did was fire the parts cannon, not diagnose so of course you still don't know what the problem is.
Diagnosing means reading TSBs and schematics, measuring voltages, using diagnostic tools etc. to find what the actual problem is.
If this isn't your first rodeo , then you didn't learn anything in all the previous ones.
Did you perform a diagnostic relearn each time you replaced parts?
Did you verify the sensor position values with a diagnostic tool?
Start with the diagnostic steps here: https://www.obd-codes.com/p2135
Old Feb 17, 2024 | 11:11 AM
Thanks but no thanks I thought I might actually help, you have a good day
Booie
Aug 2, 2021 10:02 AM
Jacob Spang
Mar 28, 2021 1:10 PM
Thswolves5
Sep 15, 2016 7:25 AM
BigRed922
Jun 30, 2012 4:55 PM
StormH2Oguy
Jan 6, 2012 7:01 PM
