Tow weight HELP! 2005 silverado 1500
Old Jun 27, 2019 | 1:51 PM
Shauhansson's Avatar
Default Tow weight HELP! 2005 silverado 1500
Hello!
I have a Silverado 1500 -2005 and try to increase tow weight here in sweden which seems incredibly difficult!
The car is imported from the US in 2008, and then got a tow weight at 5,000lbs but I want to increase it to 7,700lbs !
Sweden has incredibly worthless rules when it comes to tow weight...
I try to hunt a certificate that the car can handle 7,700lbs which seems impossible to get hold of ... there are many similar cars registered here in sweden who can tow 7,700lbs but not mine..
I need a new towbar with a certificate which can be purchased here at home, but it also requires an certificate that the car can handle it. Have tried to reach GM to ask them without a reply .. hope someone here can help me!
Some facts about my car if it would be helpful:
GU6: REAR AXEL, 3.42 RATIO
G80: Axle Positraction, Limited Slip
Z82 : TRAILER PROVISIONS, SPECIAL EQUIPMENT, H.0.
Z71 : CHASSIS PACKAGE, OFF-ROAD
C7H: GVW RATING, 6400 LBS / 2900KG
L33: ENGINE, GAS, 8 CYL, 5.3L
M30: TRANSMISSION, AUTO 4 SPD, HMD, 4L60E, ELECTRONIC
VR4: TRAILER HITCH, WEIGHT DISTRIBUTING PLATFORM
Old Jun 27, 2019 | 2:12 PM
Irish_alley's Avatar
I'm here for the party
use
https://chevroletforum.com/forum/vindecoder.php
enter your vin then click "tech specs"
Old Jun 27, 2019 | 4:00 PM
Originally Posted by Irish_alley
use
I checked and got out:
*GROSS COMBINED WT RATING
13000, 14000, 12000 lbs 12000.0 min 14000.0 max
*DEAD WEIGHT HITCH - MAX TRAILER WT.
5000 lbs 5000.0 min 5000.0 max
*DEAD WEIGHT HITCH - MAX TONGUE WT.
600 lbs 600.0 min 600.0 max
*WT DISTRIBUTING HITCH - MAX TRAILER WT.
8700 lbs 7700.0 min 8700.0 max
*WT DISTRIBUTING HITCH - MAX TONGUE WT.
1000 lbs 1000.0 min 1000.0 max
*FIFTH WHEEL HITCH - MAX TRAILER WT.6900 lbs 6900.0 min 6900.0 max
*FIFTH WHEEL HITCH - MAX TONGUE WT.1725 lbs 1725.0 min 1725.0 max
this does not tell me so much, but if i check up my friend's car it is exact same on his truck though he has more registered tow weight..
Old Jun 27, 2019 | 4:45 PM
is that all it says?
Old Jun 28, 2019 | 3:21 AM
Nah, ist much more but this is about towing
Old Jun 28, 2019 | 3:04 PM
norm your max tongue wt is 10% of the max trailer wt.. idk why your max trailer wt is only 5k, thats not even enough for a class 3 hitch. (would it stop me in the states? no lol.)
something you might be able to do over there that we can do is, get a spring shop to cert your truck or maybe even tell you what you can do to increase your G.V.C.R. but with a max trailer weight being only 5000 lbs 7k might be pushing it as i think a ¾ ton is around there
