Transfer case stuck in neutral
Old Dec 3, 2023 | 12:57 AM
lucascam05's Avatar
Default Transfer case stuck in neutral
I put my truck into 4 low while in park on accident and then it went into the neutral with the red light. I now can’t get into 2 high, 4 high, 4 low, or auto. I’m stuck and can’t get home now. My fuses are good and there was a new motor put into the case just a few months ago. Any suggestions? Grinds when I go into park also
Old Dec 3, 2023 | 9:22 AM
dpieroni3's Avatar
Can try to pull the TREC or ATCM fuse ( witch ever one your truck has) in the under hood fuse block for 30 seconds. This is the only thing that pops in my head right now, I blame insufficient coffee.
Old Dec 3, 2023 | 7:59 PM
lucascam05's Avatar
I tried pulling both and left battery unplugged overnight and I still can’t get the buttons to get out of nuetral. They just blink and then show the red again. Should I pull the motor off?
Old Feb 21, 2024 | 4:54 PM
Fisherjeff88's Avatar
Default Did you ever find the problem?
I am going through the same problem with my 2004 chevy 2500 hd. Stuck in neutral also I have no way to read the codes, but it is throwing a service 4wd code.
Old Mar 28, 2024 | 9:50 PM
lucascam05's Avatar
Default Yes
It was the transfer case shift motor. Previous owner had put a cheap new one in so I thought it was not the issue but when I pulled it out it wasn’t working just making noise. I bought a new one and put it in and it worked great
Matthew Gibbons
2007 - 2013 (GMT900)
Aug 21, 2018 4:09 PM
Terry Apple
Jun 4, 2017 4:31 PM
jlenzen69
Mar 19, 2017 9:21 AM
muddracer
Jan 1, 2015 5:07 PM
Mloreg4
Jun 23, 2014 10:47 PM
