Transmission issues
Old Aug 24, 2018 | 6:28 PM
Dustin Little's Avatar
Default Transmission issues
So my factory trans with 240k finally gave out. I bought 1 from a good buddy that was 100% g2g. I get it installed and this is where I'm at.
reverse works perfect
1st perfect
2nd perfect
3rd is like neutral until around 3800rpm then pulls like a tractor but will tach out only doing about 45mph, seems slow for 3rd. 2nd will run into the mid 50s before rpms get that high.
will not shift to 4th
from dead stop manual shifting on column
reverse strong
1st strong
2nd strong
3rd strong
dead stop in 1st rolling through to drive
1st is strong
2nd strong
3rd acts like neutral till around 3800rmp
Old Aug 26, 2018 | 4:22 PM
hicksvilleshick's Avatar
Unless it's a unknown trans issue, you sure you got all the plugs plugged in?
Old Aug 27, 2018 | 9:15 AM
Yes I suspect electrical issue. I cleaned all plugs with cleaner and blow gun. To me it feels like when it s
