Trouble starting
Old Mar 10, 2024 | 3:02 PM
Chris staehler's Avatar
Default Trouble starting
My 99 2500 gmc starts first thing in morning but as the day goes on it has a trouble starting. If I pump the gas pedal a few times it start but struggles. What could be the reason/ cause for this?
Old Mar 11, 2024 | 3:28 PM
chem_man's Avatar
15 Year Member
What engine? Are there any Diagnostic Trouble Codes in the OBDII system?
Old Mar 11, 2024 | 10:24 PM
Default Codes
Had o2 heater bank 2 sensor 1and sensor 2 changed those out and changed the fuel filter out and still does it.
Old Mar 11, 2024 | 10:25 PM
Has the 6.0 in it
Old Mar 12, 2024 | 12:55 AM
chem_man's Avatar
15 Year Member
Check the fuel pump pressure using a fuel injection pressure gauge, and also check the fuel pressure regulator - pull the vacuum line off the nipple and see if gasoline runs out of either the fuel pressure regulator or the vacuum line. If you get fuel spilling out then you need to replace the fuel pressure regulator.
YamaSakiFan
Mar 17, 2022 10:15 AM
Gmgirl1988
Feb 15, 2018 7:26 PM
andyscandys
Nov 7, 2017 3:57 AM
toby1973
Jun 23, 2017 6:41 AM
bsburban
Apr 9, 2010 3:43 AM
