Never seen this before. I was out driving and weirdly my right turn signal stopped working for like 3 seconds and then it came back on. Iv3 checked the fuses and they are all good.
I took a photo of the dashboard and went to get the codes read because I thought I had another issue.
I had a tired repaired at Costco and called them about it and of course they said the speed signal has nothing to do with the tire repair.
It's basically the front left and right. How do I go about repairing this? I know it's been a while since I've changed my front brakes and routers but I don't imagine this would solve the problem.
Reason: Ran code and this is what came up
Again this only comes on when the turn signal blinks. It doesn't permanently stay on the dash. Also I already checked the bulbs and the fuses and they are all good.
Well, since the TPMS light (the one immediately to the right of the right turn signal indicator) is not as brightly lit, and it only appears to be somewhat illuminated when you turn the right turn signal, I bet it is just the light from the right turn signal indicator light bulb "spilling over" and making it look like the TPMS light is illuminated.
