Warning lights when using turn signal help
Old Jan 27, 2022 | 6:55 AM
Mas00's Avatar
Default Code C0226 and C0222 help?
Never seen this before. I was out driving and weirdly my right turn signal stopped working for like 3 seconds and then it came back on. Iv3 checked the fuses and they are all good.
I took a photo of the dashboard and went to get the codes read because I thought I had another issue.
I had a tired repaired at Costco and called them about it and of course they said the speed signal has nothing to do with the tire repair.
It's basically the front left and right. How do I go about repairing this? I know it's been a while since I've changed my front brakes and routers but I don't imagine this would solve the problem.
Last edited by Mas00; Jan 29, 2022 at 11:35 AM. Reason: Ran code and this is what came up
Old Jan 30, 2022 | 9:28 AM
Mas00's Avatar
Again this only comes on when the turn signal blinks. It doesn't permanently stay on the dash. Also I already checked the bulbs and the fuses and they are all good.
Old Jan 30, 2022 | 2:44 PM
chem_man's Avatar
15 Year Member
Well, since the TPMS light (the one immediately to the right of the right turn signal indicator) is not as brightly lit, and it only appears to be somewhat illuminated when you turn the right turn signal, I bet it is just the light from the right turn signal indicator light bulb "spilling over" and making it look like the TPMS light is illuminated.
Old Feb 6, 2022 | 5:54 AM
Mas00's Avatar
Yea you're right, I think its because I recently had my dash lights redone.
WrenchThrower4
Nov 22, 2021 8:52 AM
Michael Barnes Jr
Aug 18, 2021 12:53 PM
99Z71
Sep 25, 2009 9:15 PM
mike23
Jan 6, 2009 10:27 PM
chvyno1
Sep 11, 2008 8:25 PM
