Water Leak from under Dashboard
Old Jan 24, 2020 | 1:09 PM
chevygirl2020's Avatar
Smile Water Leak from under Dashboard
This water leak has consumed my life. Thank you for all the responses on my previous posts about the leak! A couple days ago I took off the cowl, and did find one part of the seal where rain water drips from the windshield that was old and got spongey when water was on it. Thinking this was the spot, I applied a sealant, dried it, and replaced the cowl and wipers. Drove home happy, thinking I finally found the leak, but the next day after a downpour guess what showed back up? Now I am left wondering whats next to check. I have gotten help saying to check my AC condenser, which I think is my next step. Included is a video showing where the leak is coming from in the dashboard, note the sigh of disappointment. Any suggestions on the spot after seeing the video?
For new viewers, I have checked my vapor barrier on the driver side, my third brake light, used compressed air to check my windshield -no leaks- and recently checked under the cowl.
I love learning all this new stuff and find it honestly very fun. The not so fun part is being unable to drive when its pouring without getting a ton of water on my drivers side floorboard. I need to fix this leak ASAP, as I need my truck for day to day life in college.
Thank you!!!!
Allie
File Type: mov
Old Jan 24, 2020 | 4:05 PM
Rednucleus's Avatar
Worked a couple months to find the seam leak in my 93 Suburban. I mounted a blower (like used for drying floors) to one window and poured soapy water all over the car. Sure enough, bubbles formed over the firewall seam adjacent to the passenger door. When I hit that area with the hose it reproduced the leak. Just looking at it you would never have suspected a leak. After scraping & cleaning the area it was easy to see the water intrusion path. Pro tip: When you think you have the problem area identified, you should be able to reproduce the leak with a hose. Then when repaired, do not put things back together until hose test shows no more leak.
Old May 30, 2020 | 10:07 PM
rtamcfhgol's Avatar
I also narrowed down to similar seam leak inside my cowl (with hose testing). what sealant you used? did you remove all the seam sealant and redone fully or only the section you had leak? I see the sealant almost 1 inch high blob, what material helps to do that?
also, was the mounted blower forcing air inside the babin, which was creating bubble in cowl seam?
thanks a lot
Old May 30, 2020 | 10:31 PM
@rtamcfhgol
why don't you start a new topic for yourself. Describe your vehicle. Snap a few pics of the leak. Mention the steps you tried. You'll get much better help than resurrecting old topics.
Old May 30, 2020 | 10:33 PM
Rednucleus's Avatar
I mounted the blower outside driver's side window so pressurizing the vehicle interior. Then poured soapy water all over front of rig to find leaks.
Dug out old sealant with a pick and cleaned to bare metal with wire wheel. Used 3M Ultrapro Sealant #08300 and painted when dry.
LOL had several interested neighbors watching the blower operation as every wheatherstrip on the car was blowing lovely soap bubbles.
chevygirl2020
Apr 28, 2025 9:26 PM
carl barton
Aug 27, 2019 8:02 PM
Kan0wat
Aug 29, 2015 8:45 PM
billyboy
Jan 13, 2007 9:10 PM
