White/beige liquid under truck yesterday
Old Mar 21, 2020 | 12:18 PM
Grilly's Avatar
Default White/beige liquid under truck yesterday
I have a 2006 Chevy Silverado 3500 6.0. Yesterday I noticed the above liquid on my driveway. I guess this is likely a head gasket leak? I wonder is this a common with GM engines. My truck only has 104,000 Kim’s. as I am in Ontario Canada. I always service regularly. I have a truck camper on it during camping season so it does work but with ease. I have it booked into my local repair shop for Monday. I was wondering if anyone had similar issue.
Old Mar 21, 2020 | 1:29 PM
better not be common! LOL engines don't really run with head gasket leaks.
I don't know of any white or beige liquids.
Can you pop the hood and see where it's coming from?
Old Mar 21, 2020 | 1:35 PM
kevinkpk's Avatar
Tells me water or coolant in the oil, but leaking externally?
Old Mar 21, 2020 | 1:42 PM
Grilly's Avatar
Yes it was in the driveway when I popped the hood could not see any leaks. I went on YouTube and the white substance is usually coolant in the oil. The origin seems to be at the back of the engine.
Old Mar 21, 2020 | 2:38 PM
kevinkpk's Avatar
I'd strongly recommend checking the engine oil. If the level is ok, not overfull etc. then look at the transmission, it might be a leak in the radiator cooling line, ans leaking out a seal. Also, check your coolant for oil, and low level.
Old Mar 21, 2020 | 6:23 PM
Grilly's Avatar
Good point Kevinpkp Never thought of that.)
Old Mar 21, 2020 | 6:31 PM
Grilly's Avatar
Thanks for all your comments guys much appreciated.
Chevy-guy3
Mar 23, 2025 5:32 PM
maddog516
Mar 22, 2014 11:28 AM
grubbs11
Jun 28, 2010 4:07 PM
golfer260
Apr 22, 2010 5:17 PM
74chevy4life
Apr 21, 2008 11:42 PM
