windshiled washer pump
Old Jul 6, 2024 | 4:35 PM
sk47's Avatar
Default windshiled washer pump
Hello; Noticed blue tinged drip on my carport floor. Right under the washer fluid tank. Spent a couple hours removing battery, battery tray and finally the washer fluid tank. The tank was fine with no holes or splits. Signs of a leak around the base of the pump. Put everything back so I could use the truck.
Went to a parts store and got a new pump. Here is the point of this post. I was able to get at and remove the old pump then replace the new pump with the tank in place. Took maybe 15 minutes. A bit tight but doable. $20 for a new pump.
Took the old pump apart. Best I can tell is a rubber O ring somehow was out of place and the side of the housing was split which holds the lower section of the pump in place. The old pump was working ( pumping) so i siliconed the O ring in place and threw it in my spare parts bucket.
Jeanette Hamilton
Oct 5, 2013 5:51 PM
db13
Oct 23, 2011 4:41 PM
isrummell
Aug 28, 2011 7:06 PM
sirsedrith
Nov 4, 2009 10:41 AM
