07 1500 blower motor wiring
Old Apr 27, 2020 | 12:54 PM
Lowmanauto's Avatar
Default 07 1500 blower motor wiring
So I bought a 07 gmc 1500 the blower would not work. I noticed I had no power to the blower or resister. Turns out someone ran a wire from the black or brown wire on the blower switch to a fuse in the box. Can I get a wire diagram to fix it right?
Old Apr 28, 2020 | 6:50 PM
Lowmanauto's Avatar
Anybody?
Old Apr 28, 2020 | 10:43 PM
Gumby22's Avatar
Does it have automatic or manual AC control? They’re basically the same set up but use different cavities in the connectors - I can get the correct diagram for you tomorrow.
Old Apr 29, 2020 | 2:53 AM
Lowmanauto's Avatar
Manual it has the *****
Old Apr 29, 2020 | 12:32 PM
Gumby22's Avatar
Ok, this should be what you need - one thing to note - the wires that run off the right side of the diagram (circled in red) to the 2nd page only run to the junction block at the right end of the dash (can be seen by removing the end cover).
The wires that supply power and control to the blower resistor (labeled as control module) circle back to page 1. If you really think you’ll need page 2 or 3 I can post it, but for now, here’s the connections starting at the resistor:
Power supply - Red wire - #9 connects to #13 - Red/Black wire back to fuse box
Speed control - Purple/White wire - #10 connects to #15 - Gray/Black wire back to control panel
Old Apr 29, 2020 | 1:03 PM
Lowmanauto's Avatar
This one will help but I mainly need the one that shows the blower control **** and switch assembly that's under the radio
Old Apr 29, 2020 | 1:57 PM
wouldn't that be the "blower motor control module" at the top of the diagram?
Old Apr 29, 2020 | 3:28 PM
Lowmanauto's Avatar
I think that's the resistor as the blower motor plugs into that but you may be right let me poke around on the Google
Old Apr 29, 2020 | 6:00 PM
Gumby22's Avatar
That’s on the left side of the diagram - the box with “HVAC Control Module” underneath it.
Old Apr 29, 2020 | 6:01 PM
Lowmanauto's Avatar
Awesome
