2008 4.3L Silverado won't turn over
Old Nov 1, 2022 | 8:28 PM
  #11
rcorn1031's Avatar
Banned
Default Underhood fuse block
Originally Posted by hgoodwiniii
I did an OBD scan today and got code U0100 (Lost communication with ECM/PCM). I also tested the fuses under the hood with a test light. Fuses 4, 8, 13, 18 and 24 are not getting any power. They are all aligned in the same column one below the other. Fuse 4 is the engine fuse. Wiring looks good. Seems like the ECM may be out. Anyone with any thoughts? Thanks.
There is a printed circuit board directly below those fuses and relays , There could be a faulty foil trace that feeds the unpowered fuses .
It is more likely that than a bad ECM . What you need to do is have an actual wiring diagram that also shows the circuitry on that board from first point of entry to final output of the wiring harness .
Or trip to the junkyard to get a used fuse block from a like donor vehicle ….
Old Nov 1, 2022 | 8:43 PM
  #12
hgoodwiniii's Avatar
Ok, thanks; So I will pull the underhood casing that holds the fuses and relays and check the circuit board underneath that casing, correct?
Old Nov 1, 2022 | 8:56 PM
  #13
rcorn1031's Avatar
Banned
That is what I would do based upon your observation of a lineal failure to supply voltage to a row of fuses . Keep in mind you might need a magnifying glass to see where the foil is cracked or broken . It could also be a bad solder joint on the supply terminal for that row of circuits .
Heck you might even get a part number from the circuit board . Best of luck and Patience is your friend on this project .
Old Nov 1, 2022 | 9:01 PM
  #14
Ok, thanks. I will check it out and report back.
Old Dec 30, 2022 | 11:15 AM
  #15
Btyree26's Avatar
Hey man, I’m having the same issue. Have you gone any further?? Have you figured it out yet? I’ve tried everything I can think of.
Old Dec 30, 2022 | 1:59 PM
  #16
Hi Btyree26 - No, I'm still stuck. I have not figured it out yet. I had to stop working on it because of foot/ankle surgery. I did pull the underhood fuse box like rcorn1031 suggested but I did not see a printed circuit board underneath on my 08. There's only wires and connectors only underneath mine.`
https://www.gm-trucks.com/forums/top...errors/page/2/
https://m.youtube.com/watch?v=Y6nTQ_mZn14
https://m.youtube.com/watch?v=2-qnsfC5o7Q
I will definitely give an update when I get it figured it out. Please do the same if you figure it out before me. Thanks.
Old Aug 1, 2023 | 2:01 PM
  #17
Finally - got it figured out; Took it to an electrical shop. They found that both the ECM and BCM were out on the truck. I didn't believe it that both could possible be out at the same time at 1st but the shop gave me the old parts and I reinstalled them one at a time and the vehicle was back to not starting. I put them back and it runs fine.
MaynardHolmes
Blazer
Sep 18, 2022 11:27 AM
Mous
Jan 17, 2021 7:20 PM
kota1franco
Cobalt
Feb 17, 2020 1:50 PM
old99
Apr 19, 2018 9:21 AM
jpattt24
20
Oct 30, 2015 9:52 AM
