2008 Chevrolet Silverado flex fuel po300 help
Old Feb 10, 2022 | 5:45 PM
Prestond201's Avatar
Default 2008 Chevrolet Silverado flex fuel po300 help
2008 5.3 flex fuel Chevrolet Silverado po300 hooked up to computer misses only when idling it misses on 1-4-6-7 but once I drive it stops missing and check engine light goes away I’ve put a fuel pressure regulator,fuel pump,spark plugs,maf sensor and nothing has helped I also done a fuel pressure test and it’s reading kinda high around 80-90 psi with truck running if you have any idea what it could be please let me know thanks
Old Feb 11, 2022 | 10:22 PM
oilcanhenry's Avatar
https://www.motor.com/wp-content/uploads/Trouble-Shooter-Nov-2012.pdf
Hope that helps.
Old Feb 25, 2022 | 9:41 AM
Don Palmer's Avatar
Those cylindrs are the afm cylinders. At idle lower oil pressure causing lifters to not function properly, misfire. At road speed, higher oil pressure operate normally?
08_Impala
Aug 17, 2019 1:01 PM
TonyK2008
Feb 25, 2018 8:48 PM
Brian Swartwood
Nov 4, 2017 9:40 PM
Brian Swartwood
Nov 4, 2017 4:51 PM
DerekShiekhi
2014 - 2018 (GMT-K2)
Feb 25, 2016 7:47 PM
