Notices
Old July 23rd, 2015, 5:07 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Brakes
Print Wikipost
2008 Silverado cruise control is not working
Old September 2nd, 2017, 2:10 PM
  #81
Israel Kobey's Avatar
Default Cruise control intermittent or not working
I want you to know I had the intermittent working cruise control, then stopped completely on my 2007 Silverado 1500 LT extended cab with 5.3 engine 2wd Z71 suspension. The light on the switch came on but the light on the dash didn't light up showing it engaged. I replaced the accelerator position sensor and my cruise control worked perfectly. That was until last night. After a slight acceleration my check engine light came on and the truck went into reduced engine mode as well as the message in my message center. I cleared the code, the truck runs fine...but cruise control doesn't work. I don't think you have a brake switch so much as an accelerator position sensor problem.
Old September 20th, 2017, 10:40 AM
  #82
kkgreene's Avatar
I am having the same problem. Wow, if it is a short. I may have to just live with out it.
Old February 9th, 2018, 12:42 PM
  #83
New User
Awaiting E-mail Confirmation
Dave58's Avatar
Default 2010 Silverado
Replaced the brake light switch but no luck. Shop seems to think it's the Set switch on the steering wheel.
Dealer wants $143 just to hook it up to the computer.
This is really frustrating.
Old March 22nd, 2018, 6:14 PM
  #84
Kat4's Avatar
The on off light on my 2008 comes on but CC will not engage. I have been thru 3 switches and the CC works for a mile or two then disengages and wont come back on after. Any ideas?
Old March 24th, 2018, 1:34 PM
  #85
woosch's Avatar
What switches did you replace?
Old March 24th, 2018, 5:55 PM
  #86
Kat4's Avatar
The break light sensor
Old March 26th, 2018, 6:38 PM
  #87
woosch's Avatar
Default Cruise Control
Have you tried pulling up on your brake pedal. I had another Silverado that acted up and my brake lights would stay on at times and would mess the cruise up
Old March 27th, 2018, 7:05 AM
  #88
Kat4's Avatar
Nope didnt work
Old March 29th, 2018, 4:08 PM
  #89
woosch's Avatar
Default cruise control
Nope didnt work
I am unsure of what else to try. I looked back through the thread and someone else had the same issue and the switch didn’t fix it either.
The only other guess I have is if the plug itself is bad but I do not have any idea how to test it. Sorry
Old March 29th, 2018, 4:53 PM
  #90
Kat4's Avatar
No problem thanks anyways!
Quick Reply: 2008 Silverado cruise control is not working
