2008 Silverado front end noise
Old Jul 10, 2019 | 9:30 PM
DDS35's Avatar
Default 2008 Silverado front end noise
Hello all,
Just recently purchased an 08 Silverado with the 5.3, 93K miles. Noticing some front end noise, it's a low hum/howl/grind, not sure how to exactly describe it. It's a constant, rotational noise, it never changes when I turn or brake and doesn't matter what speed I'm at. The truck rides really smooth and straight at slow or high speeds, I can feel a real small vibration in the foot pedal though. I'm wanting to take a look at it myself and hopefully won't need to bring it in somewhere, hoping to get some advice on what might be the issue. Any information is much appreciated.
Thanks,
Dustin
Old Jul 11, 2019 | 12:54 AM
oilcanhenry's Avatar
Originally Posted by DDS35
Hello all,
Thanks,
Dustin
Likely bearings, but MIGHT be brakes, but I doubt that.
Old Jul 11, 2019 | 1:02 AM
KChevy75's Avatar
Can you hear it from the engine bay while parked or only while driving?
Old Jul 11, 2019 | 5:40 AM
DDS35's Avatar
Thanks for the responses, I did Jack the truck up and check the front tires for play like you would see from bad bearings sometimes but they were tight. And it doesn't make the noise when stopped, only when moving.
Thanks,
Dustin
Old Jul 11, 2019 | 3:07 PM
KChevy75's Avatar
Possibly a bearing or race surface has become pitted. That'll cause the sound you are hearing.
