Old Aug 10, 2015, 11:17 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
2008 Silverado Radio/Speakers issue
Old Jun 10, 2014 | 8:10 AM
  #161
therewolf's Avatar
Originally Posted by Lon
I have this issue as well on a 2005 2500 HD. I thought it was because the guy before me had aftermarket audio equipment and pulled it all out. Here is the odd thing. When I take the dash apart and pull the radio out. Before disconnecting it the front speakers come one, but they fade in. If it was a short, they would cut on or off, not fade in and out. When I put the stereo back in the dash, the front speakers get static and fade out. In addition, I have no base what so ever. I am thinking the stereo itself is shot. Between no bass effecting all speakers and the front speakers fading in and out, it has to be the stereo.
Also, what color are the stock speakers? The 4 I have in my doors are blue, which leads me to believe they are after market.
What commonly happens is the aftermarket speakers can't handle the
new amp, which is guaranteed to a certain wattage, but usually ships
with a RMS wattage 15-40 watts higher than the spec "guarantee".
Case in point: my Rockford Fosgate specs at 55 watts per channel,
but when I got the unit, it actually pushes 77 watts RMS. So far I have
blown out a set of MB Quart component tweeters, and a set of
Boston Acoustic component woofers.
As to OEM speakers, they are charcoal colored plastic and cardboard,
and surprisingly good sounding for such cheap manufacture, all things
considered. IME anything with color is probably aftermarket, or custom
ordered at time of purchase, like Blaupunkt, or Bose.
Old Jun 10, 2014 | 10:35 AM
  #162
Lon's Avatar
Lon
Thanks for the information. They are dark blue so I am sure they are not stock. I think I want to replace the head unit any ways so I can get BT for my iPhone.
Old Jun 10, 2014 | 11:29 PM
  #163
Pugly's Avatar
generally it's a lack of power that destroys speakers
my OE were like what therewolf described - cheap junk
I'm more than pleased with my Sony DVD receiver, Hertz Energy speakers, JLAudio amps and my Pioneer sub.
Don't buy cheap.
Old Jun 25, 2014 | 11:28 AM
  #164
hogrider08's Avatar
After reading all these posts I have come to the conculsion that the factory Chevrolet speakers in my 2008 Silverado are bad. So...I just ordered replacement speakers from Crutchfield and will r & r the junk factory speakers. I'll be back with a post install report.
Old Jul 17, 2014 | 5:08 PM
  #165
crazysurf's Avatar
2005 Suburban. Front passenger side speakers keep going in and out....no moisture issues. Now the CD player won't take a CD...ejects fine (from as far as I dare to insert the CD), but won't take the CD.
Old Jul 18, 2014 | 10:30 AM
  #166
crazysurf's Avatar
I pulled the radio fuse as mentioned elsewhere and it fixed the CD player issue. Thx everyone......now on to fixing the speaker problem.
Old Sep 4, 2014 | 7:28 PM
  #167
skeeterhawk's Avatar
Default Bad Speakers 08 Crew Cab
Ordering all four. Trading in the truck soon. Will not be another Chevy. Do you think the next President will bail them out again?
Old Oct 19, 2014 | 9:20 AM
  #168
bl652's Avatar
Default problem speakers sierra 2008
Originally Posted by southerngent2no
I have a 2008 Silverado ls and I had problems with not hearing the turn signals or warning beeps when you leave your keys in ignition. I did some checking and found the door speaker on the drivers side was not working, which all these alarms are designated to come through. I ordered some big kick butt speakers installed them and have got everything working again.
The speakers GM installed were cheap.....
problem solved by changing speakers,thank you for your help
Old Oct 30, 2014 | 2:15 PM
  #169
czachcross's Avatar
I noticed that whenever I left the front passenger door in the sun for an hour or so in the summer the low end speakers would kick in. Anyone have any idea why?
If the truck cooled down over night, the next morning they typically would not work again. They never work in winter as it never gets hot enough to heat the side of the car.
What is the sun heating that allows the speakers to work?
EDIT:
I took the door panel off and connected a household stereo speaker and it worked. So it's definitely the truck speaker.
I posted pictures here of the inside of the door.
http://mysilverado07.blogspot.com/20...blog-post.html
You can see where water must be coming in and how I connect and ran the wire for the new speaker.
Old Nov 6, 2014 | 9:40 AM
  #170
czachcross's Avatar
Default Burnt Coil
After cutting open the speaker, I found the coil to be burnt.
I'm not sure why a hot day would reactivate the speaker...
