Last edit by: IB Advertising
- Chevrolet Silverado GMT800, GMT900, and K2XX Stereo Diagnostic
Guide to diagnose trouble and recommended solutions.
2008 Silverado Radio/Speakers issue
heres a question for u guys having speaker problems. since mine started ive noticed at times my doors filling up w water after or during hard rains. im leaning toward this playing a factor in my speaker problem. Like stated before mine works alot more in the summer when its dry and never works in the winter when its wet outside. ive actually had to pull the strip under my door and let it drain before it was slushing around so bad. Any of u others noticed ur doors taking on water!!!!! ill have to say this is my first chevy ive bought in a long time and it will be my last. Between the doors leaking speakers going out and having to replace my door handles 6 times so far bc they pull rigt off the door im about fed up with it!!!!!
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> woogie1667,
This may be caused by a short. Do they work intermittently?
Louis
GM Customer Service
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> woogie1667,This may be caused by a short. Do they work intermittently?
Louis
GM Customer Service
I keep seeing the Customer Service folks telling people to take the issue to the dealership. They are charging way too much money to diagnose a quality issue. This needs to be a recall issue. I have a 2008 Silverado that has the exact same problem as everyone else is having. I also have a 2008 Impala that my agency has issued me for a patrol car that is having the same issue. This is definitely a Chevrolet quality issue and it is frustrating to see Chevrolet is not willing to step up and fix it.
I have an 08 Silverado crew cab long bed Duramax diesel that has had a problem with the front speakers. After pulling the front door panels off to check for loose connections and finding them all secure, I decided to replace all four door speakers with some Pioneer after market units and replacing the speakers cured the problem. The rear speakers always worked but the front ones would only work once in a while. Thanks to all for the help.
Ed
Ed
2008 chevy Z71, 50,800 miles, speakers on the driver side come on and off at random, junk.
Plus I have this sound that is driving me crazy. sounds like a cricket in my truck, happens when I speed above 30 mph, and when the temps are 60 degrees and above.
I am very dissapointed with the chevy truck I have, I am thinking next time going to another brand.
Can not afford to take to dealer for them to charge and tell me what is wrong.
I feel if there is this big of problem, chevy should recall them!
We are having the same issue. Thought it might be a wiring issue but all the wires were fine. Went to look at maybe the radio was bad. Took out the radio and it was very hot to the touch. The radio place told me i needed to replace my radio. I have but now I can't find the factory amp to make all of the speakers work. Any help with the location of the factory amp?
