Old Aug 10, 2015, 11:17 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
2008 Silverado Radio/Speakers issue
Old Jul 27, 2012 | 9:06 AM
  #51
Airspeed's Avatar
My 2008 LT Suburban has the same two issues. My front door speakers and possibly one of the rear door speakers are intermittent and are mostly off but come on every once in a while. Only the rear speakers and dashboard diamond tweeters work consistently. Also, I discovered by accident that if I stick my foot under the brake pedal and lift up, the cruise control will sometimes come on. I'm interested to try this I found:
Originally Posted by mark1500
Well I had the same issue with my cruise and found something on the web that finally worked. There is a brake switch that is connected to the brake pedal and master cylinder rod under the dash. I removed the clip and harness and you can take it out of the vehicle. I took the cover off and found two of the contact pads had black marks on them, so I took the switch completely apart and cleaned the contact areas with 1000 grit sand paper. I re-assembled and installed the switch and it has worked for the last month on demand every time without a hiccup. Seems this is the root cause and although it may happen again it was an easy fix. The switch could be replaced as well, but nobody was open(weekend) which caused me to investigate myself.
Old Jul 28, 2012 | 6:39 AM
  #52
Ice Pop's Avatar
Default Speakers Suck
Originally Posted by sledheadred
wow, im having same problem, guess no one has the answer eh?
i replaced all 4 speakers... took about 3 hrs. that was three weeks ago and everything is working well. I check the balance / fade almost daily and have had zero issues. no issue w/cruise control.
Old Aug 17, 2012 | 5:53 AM
  #53
theherd's Avatar
Default Silverado door speakers
All you people having door speaker issues it is not the wiring or head unit but the speakers themselves. I have changed out my factory radio cd player for a Kenwood head unit with Ipod connection but retained the factory speakers and it sounded pretty good until the door speakers started to cut in and out. Have replaced the door speakers with Pioneer 6.5 3 ways. Sounds great. Can I put the same ones in the rear side panels? I own a 2 door '06 silverado long box.
Old Aug 18, 2012 | 12:49 PM
  #54
edwarda10pilot's Avatar
the herd:
I don't know about the 06 but my 08 long bed uses the same speakers front and rear. I went to www.crutchfield.com and ordered some Pioneer speakers. The nice thing is that the speakers came with some speaker adapter cables that interface the new speakers to the Chevy connector and they come with a special adapter that allows the speakers to mount to the receptacle in the door. I am very happy with the speakers and installing them solved my problem.
Ed
Old Sep 21, 2012 | 2:28 PM
  #55
4pepper's Avatar
Same Thing on my 08 Silverado. Of course It's now out of warranty. With so many posts and probably thousands of people that haven't seen this site to describe their issues, It sounds like it could definately be a good reason for a recall. It sounds great when the radio and speakers work, but horrible when it acts up. Then only half the speakers function and they sound distorted, then when it decides to work properly again, It blows you out of the truck and scares the crap out of you.
Old Sep 22, 2012 | 11:43 AM
  #56
duckmaster1's Avatar
You would think they would want to keep coustomers happy, almost time for the average owners of 2008 to trade in for new ones, but with problems like this, I am thinking of looking around, my passenger side control from the drivers side window control does not work now, only on warm days,I am going to try to see if just the panel for the windows comes out to see what is wrong with it. But as for a recall, not a chance, not a safety issue so no need to.
Old Sep 23, 2012 | 2:07 AM
  #57
crewcabman's Avatar
Default same problem on my 08
i have a 08 crew cab z71 Lt and my driver side front and back speakers come on and off as well most of the time they don't work and then they just come on ! have had an audio shop look at it and they say its the speakers just don't have the money to replace them right now! why cant one of you Chevy reps do something about this problem? i have a 97 Chevy silevrado wit 328000 mile on it and still own it this why i buy Chevrolet but must admit not as impressed with the 08 as i still am with the 97 customer satisfaction seems to not be high on a priority list anymore! just my 2 cents!
Old Sep 25, 2012 | 2:56 PM
  #58
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> 4pepper,
Have you had the vehicle inspected for this issue?
Louis
GM Customer Service
Old Sep 26, 2012 | 12:34 PM
  #59
dbest607's Avatar
So if Chevy knows that there is a problem they need to do something to fix it. My brother, father-in law and i have the same 2008 1500 and are all having this problem. So i guess the olny thing to do fix it is to replace all of my speakers.
Old Sep 26, 2012 | 7:47 PM
  #60
Chevy customer service Lou, do you report any of this about the radios to the GM warranty or claims dept???
Just curious, all these guys are saying the same about the speaker on the same side and the same year truck, sounds to me there is a problem that GM needs to address to current owners.
I am going to replace mine soon when I get the money, but it REALLY stinks when your radio does not sound good because of cheap factory speakers!
