2009 5.3 too lean
Old Feb 20, 2026 | 5:45 PM
benyamin's Avatar
Default 2009 5.3 too lean
i am working on a 2009 gmc sierra 1500 4x4 5.3 6l80e and thee oil pump when out and i put a used engine in it it with a new oil pump and i had a misfire and lean codes and i replaced the intake manifold gaskets and i thought that fixed it and i had driven it 80mi and was about to give it back i the check engine light comes on and it has a hiccup everonece in a while but only when accelerating at low speeds has new plugs, wires, i have swaped coils from the old engine that worked, o2 sensors all 4 im at a loss of what to do next. so any help would be greatly appreciated thanks.
here are the codes
https://usait.x431.com/Home/Report/r...type/D/l/en-us
Old Feb 20, 2026 | 9:23 PM
lonestarmechanic's Avatar
Sometimes your injectors will hang open causing codes related to this. With whatever cylinder is misfiring, I would see if your injector is hanging open.
Bigred205
Apr 12, 2022 7:54 AM
Callaway
2007 - 2013 (GMT900)
Feb 14, 2022 3:55 PM
Nate30326
Jan 25, 2018 10:09 PM
Preliator
Jul 29, 2017 3:04 PM
Copedawg
Mar 17, 2011 6:08 AM
