2011 Chevy silverado 1500 High and low beam problem.
Old Sep 5, 2023 | 5:46 PM
Kray41's Avatar
Default 2011 Chevy silverado 1500 High and low beam problem.
Was having problem with low beam bulbs going out every couple weeks. I installed new headlight wiring harness on both sides and now none of my lights will work except for my turn signals. I checked fuses and relays and everything was fine. I even tried plugging old wiring harness back in and still couldnt even get my high beams to turn on. Help plz.
Old Sep 6, 2023 | 11:07 AM
Welcome from Florida. Check the wiring harness at the plug you used to make the connection. There might be a pin that came loose or wires that came loose or were damaged.
Old Sep 12, 2023 | 4:50 AM
DesireeDurgan's Avatar
Thanks for the advice, I will check it as you have explained. But before that, I wanted to earn some money and I already found https://casinosanalyzer.com/online-c...sinocastle.com website where I found a lot of the best CasinoCastle bonuses with reviews. And by reading those reviews, I can easily find the best trustworthy online real money gaming site through which I can make money while sitting at home. Now, I don't have to go anywhere to earn money because I can earn money by staying at home only.
Scott Sanders
Jun 3, 2019 8:56 AM
Andrei Sokolov
May 22, 2019 3:58 AM
mausc
Jun 27, 2017 1:18 PM
Barberryn
Jan 18, 2015 11:57 AM
atvkid4eva
May 24, 2013 7:07 AM
