2011 Silverado passenger headlight out
Old December 10th, 2019 | 6:25 AM
Victor Brent's Avatar
Default 2011 Silverado passenger headlight out
I’m literally stuck and fed up. Brand new wire harness, new bulb, fuses aren’t blown, and everything works from brights to turn signal but I cannot get the damn low beam passenger headlight on!!!!! Few weeks ago I could wiggle the old wire harness and it would come on so that’s why I switched everything to new after it go to the point I couldn’t wiggle the wire to make it work. I AM SO LOST on what it could be
Old December 10th, 2019 | 7:18 AM
When you say new wire harness, how far back from the bulb does it go? Check the wires further back if possible.
Old December 10th, 2019 | 8:59 AM
I didn’t go back further then the main harness right behind the headlight.
Old December 10th, 2019 | 1:04 PM
Irish_alley's Avatar
I'm here for the party
not sure about yours but on my 04 imp the low beams are on two separate fuses. took me some time trying to figure it after tracing wires and testing them i decided to go back into the fuse box under the hood and found a fuse not even labeled for the headlights as my culprit. cant think of what it was named right now but i would go back and check all your fuses
Old December 16th, 2019 | 11:20 PM
DarthBurns's Avatar
If you replaced the socket, how did you connect to the old wires? The space is so confined, I'd think it would be difficult to get a good crimp on a splice connector, if that is what you used to . Do you have a multimeter to verify that you have power at the terminals inside the socket?
Tim0625
2007 - 2013 (GMT900)
July 1st, 2019 8:26 PM
Richard S Tripp
January 22nd, 2019 8:06 PM
truck2015
April 6th, 2018 2:27 PM
Philthytoo
May 24th, 2010 3:06 PM
cwm921
January 13th, 2009 6:12 PM
Quick Reply: 2011 Silverado passenger headlight out
