2011 Transmission Temperature
an acceptable heat range. I would certainly add an external cooling unit to your vehicle and perhaps a temp.gauge if you believe that you will need it. Will you be towing with this vehicle or hauling lots of weight? If so I would absolutely use an external cooler, and change AFT fluid and filter more often. That will add many miles to your automatic transmission, no matter what make or model.
I agree with oil's reply. Anything over 200 is too hot. 175 would be the max I would want to see. Gm has a temp to fluid life chart and 200 is on the higher end for shortening the life of the transmission fluid. I run 170 towing with my hd after adding an aftermarket trans cooler. I was running 180-200f after my rebuild and decided to upgrade the cooler.
I like my granny gear in a stick but the allison is perfect for towing as far as I'm concerned. Put it in tow mode and it because a beast. Engine breaks itself to almost a stop. First gear gear ratio is perfect for take off with any load. Torque converter begins to lock up in second gear in tow mode to keep heat down while towing heavy. Love it.
tfokerts
Jul 21, 2017 10:25 PM
doug727
14
Nov 21, 2011 7:13 PM
