4.8L Frost Plug / Block heater location
Old Oct 21, 2023 | 3:10 PM
Krupaloop74's Avatar
Default 4.8L Frost Plug / Block heater location
Does anyone know where the frost plug is located to install a block heater? There are no helpful videos that I have found, and it is not in the same place as the 5.3L
Help!
Old Oct 21, 2023 | 5:02 PM
engine block coolant heater
Old Oct 21, 2023 | 6:34 PM
Assuming that I’m looking for the same type of plug (hex m17) ? This would be behind the exhaust if I’m seeing the image and arrow correctly, yes?
Old Oct 21, 2023 | 8:23 PM
arrow points to the front, so you're looking at the bottom drivers side, rear (the end by the firewall) The cylindrical object right below is the oil filter.
(please use the quick reply button. no need to quote)
Old Oct 22, 2023 | 2:58 PM
Are we talking about those round silver pieces, I’m assuming the larger one..? And is that a cover for the plug, or is it the actual plug itself?
Old Oct 22, 2023 | 6:11 PM
way off. that's your transmission.
I can see your black oil filter in the background there. You need to look above it. It's not going to be easy to get to.
I wouldn't be surprised if you had to gut out half your engine bay, or take the engine out to access the port.
Old Oct 22, 2023 | 6:20 PM
You’re just a whole barrel of good news 😑😑😑
thank you for the reply. Wish me luck.
On the chance I don’t do it myself…..any idea on what it costs to install one?
Old Oct 22, 2023 | 6:33 PM
No idea. You have to ask your mechanic. However you can get heat pads that you stick on to the oil pan. That might help to get things warmed up a little faster.
ukrkoz
Dec 13, 2012 8:56 AM
superman003
Dec 8, 2009 8:06 AM
FeelTheThunder
Dec 14, 2008 5:17 PM
Hardin Thicke
Feb 20, 2007 12:22 AM
gerryyf
Nov 25, 2006 11:09 AM
