6.0 question.
Old Jan 23, 2020 | 5:11 AM
medic610's Avatar
Default 6.0 question.
Hey all. Im brand new to the forum, and i have a 2011 Silverado 2500hd with 73545 miles on it. I picked it up used in October with 70550 mi on it.
Right now It’s about 20 degrees in Pennsylvania Anyway, I went to start the truck and it fired up no problem then the tach dropped down to about 500 rpm, and I noticed a difference in the motor like it wanted to die. Then. It immediately kicked up to around 1500-2000 rpm. It only did this when initially started it. Cold. Otherwise the motor runs fine.
Could this be an injector issue?. I was going to go out later for injector cleaner, as I’m not sure when they maintained last. Any and all advice would be helpful thanks!
Old Jan 26, 2020 | 6:59 PM
Ilovemychevyltz's Avatar
I’ve this happen before, no check engine light on. I’m thinking it’s just a random computer quick rpm drop, not related to a misfire or injectors issue
Old Jan 27, 2020 | 9:20 AM
medic610's Avatar
is this a warning sign that the computer is going out on me?
Old Jan 27, 2020 | 3:24 PM
Irish_alley's Avatar
I'm here for the party
doesnt sound like a computer problem. could be a signal issue somewhere but clean the MAF with the proper cleaner and run some injector cleaner. dont just add 1 can to a 1/4 tank of fuel if it say 1 can for 20 gal then do that
Old Jan 27, 2020 | 5:29 PM
medic610's Avatar
I bought some gum out injector cleaner. I just followed the directions. I never messed with injectors or anything give me a carb and we’ll be good. Anyway we’ll see what happens. Just need it to get as cold as before
Jason2500HD
Oct 15, 2013 6:29 PM
timjame
12
Oct 24, 2012 8:02 AM
dusfermc
17
Dec 9, 2011 4:25 PM
jcollin160
Dec 5, 2011 4:34 PM
deadwood
Dec 28, 2009 6:02 PM
