coolant leak
Old Nov 30, 2018 | 2:59 PM
lonewolf55w's Avatar
New User
Awaiting E-mail Confirmation
Default coolant leak
I have an 07 Silverado classic crew cab, It sprung a leak in the hose that goes to the coolant surge tank and the engine block. there is no petcock to drain the radiator. from what I have read you have to remove the lower drain hose to drain the radiator.is that the hose that is located on the bottom right (passenger) side of the radiator? I have to replace the hoses(which I Have).
Old Nov 30, 2018 | 5:08 PM
oilcanhenry's Avatar
Yes the lower hose is were the coolant from the radiator enters the engine to the water pump. The Top large hose is where the hot coolant enters the radiator.
