Does this pcv come out?
Old Jan 29, 2020 | 10:19 PM
BrianLs's Avatar
Default Does this pcv come out?
Went to replace my pcv valce thinking it would fix my mystery oil loss.....but it doesnt look like the pcv comes out the cover. 2012 silverado lt. Crew cab. 5.3L. 133k miles. 4x4 z71
Old Jan 29, 2020 | 10:27 PM
pretty sure that don't use a true pcv valve but rather a fixed orfice…..someone correct me if I'm wrong.
Old Jan 29, 2020 | 11:01 PM
BrianLs's Avatar
.........that sucks...was hoping for an easy swap to see if thats causing the oil to "disappear". Got an oil change and they said there was barely any oil on the stick....no leaks....no blue smoke....weird
Old Jan 30, 2020 | 8:01 PM
oilcanhenry's Avatar
Never heard of a vehicle that had a PCV valve that was non removable. Here is what I found:
https://www.rockauto.com/en/catalog/...on)+hose,11784
Correction: apparently the PCV is not serviceable on your vehicle.I suppose you could shoot some carb cleaner down the orifice:
Man I am holding onto my 98 K-1500 until I die. I don't understand this non-replaceable nonsense at all, but I AM old-school.
Old Jan 30, 2020 | 8:10 PM
BrianLs's Avatar
....wonder if that nipple sticking out the valve cover is just a tube. And the parts to be looking at is that hose?
Old Jan 30, 2020 | 8:13 PM
BrianLs's Avatar
Ive tried looking it up to. Only thing i could find is that the pcv valve was built into the cover....and had to replace the whole thing. It would be really dumb if thats what they intended for us to do when the valve goes bad
Old Jan 30, 2020 | 11:01 PM
It makes them more $$$ when it goes for repairs. What was wrong with the old PCV valve that could be changed in a minute? Hope I don't have to fool with my 2015 Malibu 2.5 throttle body. Its right next to the firewall, VERY hard to get to.
Old Jan 30, 2020 | 11:54 PM
when the pcv sytem is blocked or overcome by excessive blowby gases the air filter will get oil pushed into it. If you don't have that condition, the pcv system is probably fine. if you think you have an oil consumption problem...
-are you seeing blue smoke out the exhaust ...anytime or on hard acceleration ?
-do the spark plugs have ash deposits?
-any difference in dry and wet compression tests?
Old Jan 30, 2020 | 11:59 PM
BrianLs's Avatar
I will check the air filter tomorrow. But otherwise truck runs good. Dont notice any blue smoke. No leaks....havent checked the plugs. Firestone said my dip stick was dry when i got the oil changed......
Old Jan 31, 2020 | 12:03 AM
check the oil level is at the full mark. note you mileage and monitor the oil level and mileage. that is how you start an oil consumption study.
nf123
Nov 10, 2020 5:45 PM
BrianLs
2007 - 2013 (GMT900)
Jan 30, 2020 11:08 PM
Deepsand
Oct 26, 2017 7:48 PM
LARIDERS
May 21, 2010 9:25 PM
gregski39
Mar 1, 2009 11:47 AM
