Door locks cycling while driving
Old Apr 4, 2014 | 7:38 AM
  #31
Originally Posted by Thollowell
The shift indicator is not the problem but a symptom.
never said it was.
Hope that fix works but the repair doesn't make sense. Locks and prndrls don't cycle because the power is removed/reconnected. If it did, you should be able to create the problem by pulling and re-inserting the fuse in question.
Old Apr 5, 2014 | 6:25 AM
  #32
Thollowell's Avatar
A temperary "fix" when this occurs is unhooking the battery and reconnecting it. I guess it resets everything in the truck. When this all happens and I turn the truck off it has 0 power to anything basically as if there was no battery in the truck at all, the dealership is havin me replace these items becaus they are not covered by warranty and if this doesn't work I have to take it back to them to have them continue their diagnostics.
Old Apr 5, 2014 | 3:32 PM
  #33
Official GM Rep
Hey there Thollowell,
We're sorry to hear of this concern. Please let us know if there is anything that we can look further into for you. Please send us a private message referencing your concern if any extra assistance is needed. We look forward to hear from you!
Kristen A.
Chevrolet Customer Care
Old May 5, 2014 | 12:48 PM
  #34
mikeyg760's Avatar
i have problems with my trucks locks going up an down and the gauges turning of and on radio cutting out i took it to the dealer and they said it was the battery i got a new one and now its doing the same thing does any one know what that the problem is ??
Old May 5, 2014 | 1:20 PM
  #35
mikeyg760's Avatar
my 09 chevy is doing the same the gauges go of and on the locks up and down radio cuts of and it all happens when i press on the breaks i ben reading about it and it says its the ground cables
Old May 6, 2014 | 6:03 AM
  #36
Thollowell's Avatar
Since I replaced the + batt cable (the one from mega fuse to main fuse box) knock on wood hasn't happened again yet
Old May 27, 2014 | 8:32 AM
  #37
Thollowell's Avatar
Default Update
So after making the recommended repairs by the dealer the truck began to **** up yet again. Same issue. I left it running while it was towed in so they could pull any codes. Was just told the code pulled was for a bad ground under the truck. (Same thing that was wrong with a coworkers with the same issue). Awaiting repair will post when I know something.
Old Jul 17, 2014 | 7:10 AM
  #38
Rlhdude's Avatar
Hi Thollowell. I just found this forum after experiencing this exact same problem on my 2009 Silverado I recently purchased. It is at the dealer now and they cannot find anything and no codes are present. Did you have any luck with with finding a bad ground?
Old Jul 17, 2014 | 12:07 PM
  #39
Official GM Rep
Was there any new information that your dealership was able to provide, Rlhdude? If you'd like for us to reach out to your dealership we'd be happy to gather details about your Silverado and make sure they've consulted with all of their resources regarding this issue. Private message us your VIN, full contact information and dealership name if interested.
Amber N
Old Jul 18, 2014 | 6:19 AM
  #40
Thollowell's Avatar
They ended up replacing an entire circuit somewhere in the truck. So far it seems to have solved the problem. I cannot remember what they replaced. My dealership is Strosnider Chevrolet in Hopewell VA. Feel free to contact them or have your dealer contact them. I will say its ironic they fixed it after I requested all of my records to get my stuff together for a lemon law claim. If I can find out what they did I'll post it.
