Engine stalling. DTC P2161
Old Apr 11, 2024 | 10:40 PM
Wesley59's Avatar
Default Engine stalling. DTC P2161
2013 silverado 1500 4x4 ltz getting code P2161 that means It needs a new speed senser replaced both interneal and external becuase it cuts out like its shutting off and on and jerks door locks clik cruise disengages
sime times gas needle will go to empty and turns on low fuel on dash and screen ck engine light comes on also I woundered if it was shorting out so I rewired it from the senser to to computer Anyone have any thought ideas
or knowledge os what the heck it could be please Help! Wes
Old May 25, 2024 | 5:51 PM
Austin47's Avatar
Default Did you ever figure it out
Mine basically does the same thing did you ever figure it out
Old May 26, 2024 | 8:26 AM
Wesley59's Avatar
No so far its still a mystery, thinking about checking fuel module up under the spare tire if you find the issue please let me know
Old May 26, 2024 | 8:32 AM
Austin47's Avatar
Default I definitely will
I definitely will I have changed so much stuff and gotten no where
Old May 26, 2024 | 2:42 PM
see Diagnostic and Repair Procedures:
https://www.obd-codes.com/P2161
Old May 26, 2024 | 3:01 PM
Austin47's Avatar
I already changed the vehicle speed sensor supposedly there is one inside the transmission that’s attached to the valve body I changed the one on top of the transfer case and the other guy did both of them and that didn’t fix anything
Old May 26, 2024 | 3:09 PM
changing parts didn't fix anything? Shocking.
Old Jun 9, 2024 | 8:41 PM
Austin47's Avatar
Did you figure it out by chance
Stevemac44
2007 - 2013 (GMT900)
Apr 12, 2024 10:31 AM
Wesley59
10
Oct 7, 2023 3:26 PM
tazzmaniac
Jan 17, 2023 9:52 PM
Lisamheft
Feb 28, 2013 7:27 PM
zirmar
33
Jun 23, 2010 12:40 PM
