Factory radio wiring harness
Old Jan 10, 2021 | 12:02 AM
kodiak341's Avatar
Default Factory radio wiring harness
i got a 2010 chevy silverado im needing a factory radio wiring diagram, wire color/ description, does anyone have a diagram you could share or send me
Old Jan 10, 2021 | 7:18 AM
Welcome from Florida. Hope this helps you.
EIA Electronic Industries Association Color Coded
Yellow 12 Volt memory
Red 12 volt ignition
Orange dash light illumination
Black radio chassis ground
Blue power antenna
White left front +
White/Blk left front -
Green left rear +
Green/Blk left rear -
Gray right front +
Gray/Blk right front -
Violet right rear +
Violet/Blk right rear -
Old Jan 10, 2021 | 8:57 AM
hanky's Avatar
If you are staying with a factory ,"As built" radio , great, If, however, you are contemplating installing a different radio something to keep in mind.
Most vehicles built after 2008 use a CAN/LAN system and the radio is one of the modules in the network and when inoperative/incorrect can create all sorts of problems.
Old Jan 10, 2021 | 11:04 AM
kodiak341's Avatar
what kind of problems could it potentially create, and what would i need to do to keep from having these issues?
Old Jan 10, 2021 | 11:42 AM
kodiak341's Avatar
ok so let try this as well, can someone tell me exactly what all i am going to need to install an aftermarket radio in my truck, again its a 2010 chevy silverado and yes i do have steering wheel controls....what all items will i need to hook a radio up and still be able to utilize all the same functions as it does with the factory radio
03avalanche
Nov 9, 2017 10:29 AM
curtis1512
Nov 12, 2015 8:40 PM
hellscreation30
Jan 1, 2012 10:26 AM
deyond
Sonic (Aveo)
May 13, 2011 10:49 PM
1990 chevy truck
Apr 21, 2009 7:11 AM
