Hard Start Please Help
Old Nov 9, 2022 | 7:48 AM
Michaelprestonbishop@gmail.com's Avatar
Default Hard Start Please Help
07 4.3 obs. Only after sitting for 6to8 hrs I have to spin it over a lot to start then when it gets to operating temp it runs fine and will start fine after. Seems like I have replaced everything and there is no codes or check engine light on
Old Nov 9, 2022 | 8:04 AM
Welcome from Florida. Sounds like the check valve in the fuel pump assembly is bad. Spray some starter fluid or gas into the throttle body and if it starts right away then the fuel pump is the problem. You can add an external check valve or replace the fuel pump assembly.
Old Nov 9, 2022 | 10:58 AM
I have replaced fuel pump, spider injectors,plugs,wires,cap rotor,cooling sensor,purge valve
and after it finally starts it seem like it is over fueling bc it feels like it is missing for a few minutes and then clears out and also it doesn't pull up any misfires
BluMustard
Dec 26, 2020 12:56 PM
sertek54
Jan 11, 2019 10:54 AM
sertek54
Oct 15, 2018 7:03 PM
boagie
Oct 2, 2018 11:24 AM
gregs uplander
Uplander
10
Oct 8, 2013 2:56 PM
