How do I replace the input shaft seal on the transfer case? 2011 Silverado
Old Oct 3, 2017 | 7:53 AM
rxsly's Avatar
Default How do I replace the input shaft seal on the transfer case? 2011 Silverado
Hi gang!
Does anyone know where I can get a repair manual for a 2011 Silverado 4.8 V8 4WD (WT)?
My input shaft seal on my transfer case is leaking a bit and would like to replace it. Also does anyone know how to identify which transfer case I've got?
And one more thing sorry, when I noticed it was leaking I topped the fluid back up till it was coming out of the fill hole and put in the plug. I check it once in a while and the fluid keeps coming out of the fill hole (spills out pretty good I don't even need to take off the drain plug completely). I made sure that I was level when I filled it and that I'm level when I check it.... find that a little strange.
Thanks in advance for any ideas you guys may have!
Old Oct 3, 2017 | 3:56 PM
kevinkpk's Avatar
Is the vent line plugged? It's a simple garlock seal, you should be able to find one locally
Old Oct 31, 2017 | 7:43 AM
rxsly's Avatar
Is the vent line that rubber hose on top? Seems to be coming from the tranny?
Old Oct 31, 2017 | 3:36 PM
kevinkpk's Avatar
Post a pix of it, the shaft, and seal. The vent line (could be) just a one way valve on top, about the size of your pinky finger, or a line. Follow what you suspect is the vent line. It should just got to atmosphere. If it isn't clogged you should be able to pass air through it.
