How to tell when airflow is restricting power output
Old Jun 14, 2023 | 8:37 AM
MillersLC9build's Avatar
Default How to tell when airflow is restricting power output
Hey everyone,
I”m currently working on building an engine for my 2011 Sierra 1500. The base is an LC9, I’ve got a TSP mild cam in it with a 215° duration, forged pistons and connecting rods, ported heads and an LSXRT FAST intake manifold. I’m about to get some injectors, and a bigger fuel pump and FP regulator, but I was wondering what would be overkill? I could get 70lb injectors and a 640 lph fuel pump, but what’s the point if I don’t have enough air to make it worth it. I don’t plan on any type of forced induction either. So my real question, is there a way to use the readings from my MAF sensor to determine the maximum amount of fuel I can make use of? Thank you for any help you can give me.
-Sam
Old Jun 14, 2023 | 9:52 PM
Im not a engine builder or tuner so i can"t answer your question. I don't know the limit of the stock injectors. I will say, if you build it and the fuel trims are running lean during a high fuel demand.... then add the larger pump and injectors.
not sure you would need all that for a n/a build...boosted yes. You def don't want to go to big or it will be a guzzling pig with no power returns.
ReddZedd
Feb 19, 2023 8:20 PM
4 bangin
Jul 31, 2013 2:44 PM
aartod
Sep 30, 2009 3:48 PM
98Silverado621
Jul 11, 2009 9:02 PM
