Irregular AC Tempertaure
Old Oct 17, 2022 | 8:20 AM
00BUCKshot!'s Avatar
Default Irregular AC Tempertaure
Wanted to get some input from you guys. My 2007 Silverado seems to be having some issues regulating temperature. In order to get warm/hot air to blow, the only temperature setting I can use is 90 degrees. If I drop it down to 89 or below, it will only blow cold air. My initial thought is that the climate control module is failing but before I go spending, wanted to see if anyone else has had a similar issue or knows of a way I can test it before purchasing a new one. Any assistance would be greatly appreciated.
mfletcher2890
Mar 13, 2018 8:04 AM
Aavronle@gmail.com
Apr 21, 2015 10:07 PM
Farmerluke
Jun 25, 2013 8:13 AM
CHUCK70
Jun 19, 2011 6:48 AM
johnnyoski
Aug 8, 2010 12:11 PM
