Need help
Old Dec 23, 2024 | 7:06 PM
Martinarse's Avatar
Default Need help
I am reaching out as a last resort to see if anybody has had the same issues as me. Let me start by saying I have been to two mechanics and the dealership and the truck is still having the same issues and it's been 3 months now. I'll try to keep this as short as possible. Originally I went to start my truck and it wouldn't start or turn over it was like it had no power whatsoever and on the dash it said service four wheel drive. A few minutes later I was able to start it just as nothing had happened. Everything would be fine for a couple weeks and then it would happen randomly. If you came up and try to use your automatic locks on your fob to unlock the truck or lock it it would be just dead there would be no power to the locks. And you would get locked out. If this happened I would have to put it in neutral and start the truck and then shift it back to drive. And then everything would be fixed temporarily. So you could actually drive the truck and not be stranded. Then one day I was in the truck and about to start it and it flashed service four-wheel drive then service airbags then service traction control service stabilitrac. There may have been a couple others but that's what I remember. They just flashed one after another after a few seconds. So far I have replaced the ECM, replaced the battery, checked all the fuses disconnected my command start. Checked the connections to the battery. Any expert advice would be greatly appreciated. Chev Silverado 2012, 1500
HarmonicGray
Oct 8, 2024 10:04 AM
Bubbel305
Avalanche
Apr 24, 2021 7:17 PM
twins225
28
Sep 16, 2019 11:57 AM
Mrbadbear
Avalanche
Jan 30, 2018 3:16 PM
lilbaker87
May 17, 2011 3:58 PM
