Need help identifying a drive shaft
Old Aug 15, 2020 | 8:19 AM
Frank J's Avatar
Default Need help identifying a drive shaft
I need some guidance on a drive shaft for my current project (’53 5-window Pickup / LS engine Swap). I’m installing a gen IV LS engine with a 6L80 transmission from a 2013 Silverado. I have a good source for almost any used drive shaft, but I need to identify my requirement by model/year, not drive shaft dimensions.
To match the transmission, I need a shaft with a 32 spline slip yoke - GM 23251196 (Tahoe, Yukon, Escalade. Yukon XL, Suburban. Express, savana. Escalade EXT. Escalade ESV. All models. Avalanche. Hummer H2.) with a 4L80 / 6L80 transmission. As long as it is over 60” long (probably not standard cab, standard bed), I can have the shaft shortened. Also, the differential end u-joint cradle is not critical.
I do want to keep the driveshaft diameter 3’ or less if possible. (and obviously one-piece shaft).
Anybody have experience/suggestions?
Rambo454
Nov 8, 2016 8:17 PM
Zach Guzaitis
Jun 20, 2016 11:06 AM
socplay50
Jul 10, 2012 10:00 PM
cummins rules
Feb 27, 2012 8:26 AM
d.lebherz84
Oct 29, 2011 2:25 PM
