p0300
Old May 24, 2020 | 6:54 PM
dgs000's Avatar
Default p0300
2007 Silverado 5.3 V8 with AFM with 180,000 miles
Truck had lifter ticking sound and white smoke upon every start up which would go away after a few minutes, no check engine light
Replacement list :
- headgasket
- valve gaskets
- upgraded drivers side valve cover
- valve stem seals
- intake manifold gasket
- exhaust manifold gasket
- 8 new afm lifters
- 8 new non-afm lifters
- head gasket bolts
- engine coolant temperature sensor
- water pump
- thermostat
- cam sensor
- crank sensor
- spar plugs, spark plug wires, and fuel injectors where replaced 3 months ago
After completion of engine reassembly no longer had white smoke upon start up and no ticking sound but flashing check engine light code p0300.
Code p0300 was for cylinder #1, #4, & #7
Moved coil packs between cylinder #1 and #2 to see if coil packs was bad but no change. Set engine at TDC before installing the rocker arms.
All bolts have been properly torque and no parts have been left unplugged or uninstall.
Any possible advice would be helpful
Old May 24, 2020 | 8:03 PM
kevinkpk's Avatar
Replacement list :
- headgasket
- valve gaskets
- valve stem seals
- 8 new afm lifters
- head gasket bolts
- water pump
- thermostat
- cam sensor
- crank sensor
You didn't state if you have a valve job done.?
Old May 24, 2020 | 11:02 PM
dgs000's Avatar
Did not change the valves, took each out cleaned and reseated it with new valve steam seals.
Old May 25, 2020 | 8:29 AM
kevinkpk's Avatar
Re seated, is that in you lapped them back in? I'd suggest a compression check.
Old May 25, 2020 | 12:25 PM
Gumby22's Avatar
You say you replaced the lifters with AFM and non-AFM type - Which lifters are currently installed?
Cyl. 1, 4, & 7 are all cylinders that are shut off during AFM operation - if you’re running non-AFM lifters but still have the solenoids installed and active, that could be triggering the misfires.
Old May 25, 2020 | 1:54 PM
dgs000's Avatar
There are a total of 16 lifters.
There are 8 non amf lifters which were replaced with new non amf lifters.
There are 8 amf lifters that were replaced with new amf lifters.
Mr_Professional
HHR
13
Jun 4, 2022 4:04 AM
Matt Vardaman
May 13, 2019 11:17 AM
Yogi
Dec 30, 2015 10:40 AM
Gray_wolf_7
Feb 20, 2015 6:16 AM
xxsokol32xx
Aug 2, 2012 3:52 PM
