P0307 code is killing me
Old Mar 7, 2021 | 11:52 AM
Notarealmechanic's Avatar
Default P0307 code is killing me
My 2011 silverado is running rough and keeps throwing if P0307 codes and tgan just through some P0300. I have changed my spark plugs , ignition coil for cylinder 7 swapped fuel infectors from 5 to 7 , sea foamed my cylinders and gas tank and even took the head off and found a stuck exhaust lifter and replaced and truck is still running rough. The check engine light flashes and stabiltrac turns off . I also have 125 pressure in each cylinder aswell . Any ideas out there ? I’ve been fighting this problem for quite a few months now
Old Mar 7, 2021 | 12:55 PM
kevinkpk's Avatar
Does the problem follow with changing things around, i'm assuming not? Is it still #7? What does the spark plugs look like?
Old Mar 7, 2021 | 2:42 PM
Yes it does follow me around when I change things around . The spark plugs don’t look to bad at all
Old Mar 7, 2021 | 4:44 PM
kevinkpk's Avatar
So, if the problem of P0307 follows when you change coil, injector to P0305, I'd say you need to replace injector/coil pack. How many miles on the coil?
Old Mar 7, 2021 | 6:16 PM
I already changed the coil in #7 and swapped injectors and the same code keeps coming up which is P0307
Old Mar 7, 2021 | 6:17 PM
I have 250k on my truck
Old Mar 7, 2021 | 6:32 PM
kevinkpk's Avatar
Since the compression is fine across the cylinders, plug looks good, I don't know, but 250k, could still be a valve seal leaking oil.
itibitiguy
16
Apr 1, 2026 8:40 PM
Frank0405
Jul 26, 2020 4:16 AM
Redfishaholic
Apr 23, 2019 9:17 PM
ChevyDave007
Apr 9, 2013 2:38 PM
temills
Dec 16, 2006 6:35 AM
