P0340(Camshaft position sensor circuit)
Old Mar 31, 2024 | 1:12 PM
tinyjet2's Avatar
Default P0340(Camshaft position sensor circuit)
I have 2013 Silverado 5.3 and after I cleaned the throttle body the engine went up to 3000 rpm so I did the idle relearn procedure numerous times and never worked. While riding all of sudden the truck lost power and cut off. I towed it home and checked the fault codes and it was P0340(Camshaft position sensor circuit), P0507(Idle Control System RPM higher than expected), P0068(Throttle Body Air Flow Performance). So I replaced the throttle body, the camshaft position sensor and cleaned the Mass Air Flow Sensor and still will not crank and I still got the same permanent faults. Anyone ever run into this problem and what was the problem?
Old Mar 31, 2024 | 3:57 PM
Try boosting it from another vehicle.
Old Apr 20, 2024 | 3:43 PM
jg9's Avatar
jg9
will that really help
Old Apr 20, 2024 | 10:29 PM
you won't know if you don't try. Is it that hard to do?
Old Nov 16, 2024 | 4:36 PM
wsx7918's Avatar
Any updates on this? Im having a similar issue, just P0340 and someone took this truck to some shops and had some work done before I got it. I think maybe they took the throttle body off also.
mkcnvr
2007 - 2013 (GMT900)
Apr 5, 2019 12:57 PM
mkcnvr
Oct 24, 2018 7:05 AM
08silver07tahoe
Jan 18, 2015 9:33 PM
wis2ohio
Oct 19, 2013 10:35 PM
MyBowTieGuy
Camaro
Sep 15, 2011 12:01 PM
