Po191
Old Oct 19, 2024 | 2:58 PM
Ccrider66's Avatar
Default Po191
Getting this code on my 2007 silverado 5.3v8
fuel rail pressure sensor circute range/performance.
I've watched several you tube videos on changing the sensor sensorengine & make of truck, but they all show the sensor as being located on the fuel rail. I dont see any sensors at all on either of my fuel rails. Has anyone ran into this? Is it mounted in a different location?
thanks
Ccrider
Old Oct 21, 2024 | 1:19 PM
jfmorris's Avatar
The only fuel pressure sensor I see in the repair manual for a 2007 Silverado 5.3 (assuming NOT the 2007 "Classic" appears to be located on the firewall, inline in the fuel lines from the tank. Here's a diagram in the manual for the truck:
https://charm.li/Chevy%20Truck/2007/...0and%20Repair/
A 2007 "Classic" (GMT800 instead of GMT900) does not appear to have this sensor at all. And I will bet that the videos you've watched on Youtube are for newer vehicles than the GMT900 or GMT800.
Old Oct 21, 2024 | 1:53 PM
Ccrider66's Avatar
Default Thanks
I'd say that was it, found it on the frame even with the drivers door. Thanks for the help
QUOTE=jfmorris;508868]The only fuel pressure sensor I see in the repair manual for a 2007 Silverado 5.3 (assuming NOT the 2007 "Classic" appears to be located on the firewall, inline in the fuel lines from the tank. Here's a diagram in the manual for the truck:
A 2007 "Classic" (GMT800 instead of GMT900) does not appear to have this sensor at all. And I will bet that the videos you've watched on Youtube are for newer vehicles than the GMT900 or GMT800.[/QUOTE]
loopedr1
Dec 4, 2023 6:55 PM
chevyguy68
Aug 21, 2023 1:46 PM
jfrancom101
Apr 17, 2022 3:03 PM
kevinmedic
Mar 31, 2019 6:38 PM
wyattn1
May 8, 2011 8:18 PM
